Mike Sloan
- May 18, 2002
From reading the spec's sheet and reviews this looks too good to be true:
SPECIFICATIONS:
Continuous Average Power 200 watts x 1 (8 ohms 0.1%
THD), 400W x 1 (4 ohms 0.1% THD)
Dynamic Power per Channel 400W x 1
Power Bandwidth 5 Hz - 50 Khz
Damping Factor Greater than 100
Input Sensitivity / Impedance 2.0 V / 44 k ohms (rated power)
Frequency Response 20 - 20,000 Hz +0, -0.5 dB
Signal to Noise Ration Better than 120 dB
Total Harmonic Distortion Less than 0.1%
Output Complement 8 transistors: The output stage is based on a CLASS A/B bipolar devices by Toshiba utilizing three Toshiba JFETS for the gain stage and three Toshiba bipolar for the output.
Power Supply 800 V/A Switching adjusted to 500 V/A supporting 800 V/A peaks.
XLR connectors for balanced inputs.
Le Amp II uses no negative feedback. It uses a DC Servo circuit so there are no capacitors in the signal path and no DC offset.
Le Amp is designed so that the power board and power supply boards can be easily swapped out. This means that repairs can be made by swapping out any failed board. We plan to put a diagnostic system into Le Amp that will show what board has failed.
Price $300.00
Nohr Le Amp2 link
SPECIFICATIONS:
Price $300.00
Nohr Le Amp2 link
