nOrh speakers...complimentary amp?
Discussion in 'Archived Threads 2001-2004' started by Jack_Geo, Apr 6, 2002.
  1. Jack_Geo
    Jack_Geo Stunt Coordinator
    Jan 5, 2002
    58
    Hi!
    I just placed an order for the nOrh 5.1 video package...that's a pair of synthetic marble 5.1 main speakers, a ceramic 4.0 center, and a pair of ceramic 4.0 surroungs.
    I'm pretty much starting from scratch on my system, and I liked the looks of the nOrhs. For $950, I think they'll be just fine for now.
    I'm adding an SVS 25-31PCi to the mix for bass duty, and have an Outlaw 950 on order. It's probably overkill, but how can I pass it up for the price?
    Anyway, my question is this: Does anyone have any experience with power amps mating with nOrh speakers? What sounds good, what to avoid?
    I'm going to go used...and am thinking about Parasound...maybe a 2-channel (1000a?) and an 855? Maybe two 855's...it depends on what I find.
    Rotel's another choice...
    If anyone has some suggestions, I'd appreciate your input...and if there are any reasonable amps out there used, let me know.
    Jack
  2. Russell _T
    Russell _T Supporting Actor
    Aug 26, 2001
    579
    If you like Norh, I would check out their own LeAmps.
  3. Peter Johnson
    Peter Johnson Stunt Coordinator
    Nov 12, 2000
    136
    Ive never heard the LE amps, but I own 7.0's. They seem pretty good for $500, so I am sure they will be fine.
    Dont rule out second hand. You should be able to get a whole lot more amp for your $$.
    FWIW, I drive mine with a cyrus 3. Its a 2chan integrated. VERY good matchup, but there's no US cyrus dealer.
    Whats your budget?
  4. Terry Flink
    Terry Flink Stunt Coordinator
    May 23, 1999
    138
    10
    I am running the nOrh 4.0 video system with an Outlaw 750 amp and couldnt be happier. Mated the nOrhs with an SVS 20-39CS powered by an Adcom GFA-555II that was sitting around gathering dust. A great setup for both music and HT.
  5. Jack_Geo
    Jan 5, 2002
    58
    Thanks for the suggestions, guys...
    Russel: I saw the LaAmps, but was kind of hoping to go the multi-channel route, rather than monoblock.
    Peter: As far as my budget, it's about $1,000 for the amp(s)...less if at all possible. If I could pull off 7.1 for $1,000, that would be a bonus. I have no problems going second hand...am actively checking out Audiogon, eBay, Ubid, etc.
    Terry: I'm definitely considering the Outlaw 755 or 770...but I guess I was trying to see what amps would mate well with the nOrh's that I could find on the used market for a lot less.
    Thanks again...
    Anyone else?
    Jack
