non-flared port
Discussion in 'Home Theater Projects' started by bernard&*, Apr 27, 2004.
  1. bernard&*
    bernard&* Stunt Coordinator
    Mar 1, 2004
    56
    I'm going to build my first diy sub sooner.Is there any big diff. in performance, if i used a non-flared port tube(like PVC pipe) rather than flared one.
    [​IMG]
  2. DarrenHo
    DarrenHo Stunt Coordinator
    Feb 20, 2004
    127
    i imagine you might see more port noise with the non flared port. try it out. you could always go to a flared one later if it proves a problem.
  3. Jeremy Stockwell
    Jeremy Stockwell Supporting Actor
    Aug 9, 2001
    608
    Bernard,
    If you can provide some details about your project, you'll get better responses.
    If you're talking about venting a Tempest with a single 3" non-flared port, than you'll probably have problems. If you're talking about venting a Tempest with a 6" non-flared port, then you're probably OK.
    The flares definitely help to prevent port noise, but are sometimes not necessary depending on your specific situation.
    JKS
  4. bernard&*
    Mar 1, 2004
    56
    jeremy,
    I'll go with the tempest, adire alignment with vented FP3 3"flared port kits with 11"center tube.(cost to much) if there will be no big problem using pvc pipe I'll go with it.BTW I'll change the box size but stick to its volume 214L. I worked with Winisd in 214L, 20"Wx24"Hx34"D, I just add 1"(0.93)for the offset measurement of Winisd with respect to adire recommend(legs not included).Please help me with this calculation.[​IMG] any way thanks for reply.
  5. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    I tried the Tempest with 2 3" PVC and I did get port noise, the flared ports are much better
  6. Jeremy Stockwell
    Aug 9, 2001
    608
    FWIW, I've got a Tempest in 290L tuned to 17.5Hz with a 6" PVC (non-flared). I don't get any port noise in its operational range.
    JKS
  7. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    After all the money, time, and effort you put into the box the $20 for the port will seem minimal when you hear the port noise. Been there, done that.
  8. bernard&*
    Mar 1, 2004
    56
    Hi! Aaron,
    I think your right I'll go for the flared port.
  9. Bhavesh
    Bhavesh Stunt Coordinator
    Nov 27, 2003
    60
    bernard&*,
    you can buy the flared port and terminals much cheaper at Parts Express.
  10. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    PE also has some buy-out 3" flared ports dirt cheap, but they're only available in 9" and 11.5" lengths that aren't adjustable like the precision flared ports.
    Another way to get flared ports using strait PVC is to mount the pipe on a double thick wall of MDF (you'll probably want to double up on the baffle anyway) and then use a flush cut router bit to cut the hole then a big 1/2" round-over bit for the flare. Also gives the port a very flush look since it's actually part of the wood and not just a piece of plastic mounted to it.
    Hope this helps [​IMG]
  11. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    Bernard, I have a 5.5" non flared port in my Tempest and haven't heard port noise yet.
    Try out Adire's version of LSPcad, they have a measurement for air speed at the port, which should give you a decent indication I think.
  12. Justin Ward
    Justin Ward Supporting Actor
    Jun 6, 2002
    673
    I've got two 3" non-flared in my SBB4 Tempest. I only notice port noise when playing test tones near the tuning point at loud volume.
