Non-damaging speaker adhesive
Discussion in 'Archived Threads 2001-2004' started by Dave Choate, Mar 24, 2002.
  1. Dave Choate
    Dave Choate Auditioning
    Mar 20, 2002
    5
    I'm looking to attach my surround speakers to my antique cherry end-tables in my living room. They need to be attached (vs just placed) because of my 6 month old who loves to pull on the wires and hasn't learned the word NO yet. I've seen other posters refer to Blue-Tac and ribbon caulk. Will either of those damage the finish on my end tables? Does anyone have any other ideas?
  2. Pat K
    Pat K Stunt Coordinator
    Mar 15, 2002
    59
    How bout a hunk of metal underneath the top of the table.. will that mess up the sound? I dunno
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    3M VHB (Very High Bond) tape should do the trick and leave no residue either on the speaker or tables. May not be simple to find, as it is more of a comercial product than public, but one roll is only around $30 and will last forever. Can be used for lots of other stuff too.
  4. AaronMg
    AaronMg Stunt Coordinator
    Mar 20, 2002
    247
    You could try some rubber cement. I use it on my speakers and I find it works well. You should be able to find some at your local hardware store.
  5. Walt N
    Walt N Second Unit
    Jul 23, 2001
    417
    I think Tac N Stik (same as Blu-Tack) has the best chance of doing what you want without wrecking the finish on your tables. I've used this type of stuff for years and it works great. Firm solid support and it leaves no evidence. Use just a small dab at each corner of the speaker and when it's time to remove it, I use a strong plastic spatula to gently pry the speaker starting at one corner. You can ball up the Tac N Stik that remains using your fingers.
