Non 16x9 DVDs on a 16x9 TV...
Discussion in 'DVD' started by Daniel P, Mar 8, 2004.
  1. Daniel P
    Daniel P Stunt Coordinator
    Mar 1, 2002
    217
    ...just wondering where the subtitles are placed, in particular on Criterion's Amarcord and Andrei Rublev - or any film with a 1.85:1 and 2.35:1 aspect ratio, which are not 16x9 enhanced.
    I only know my TV, and a non 16x9 disc can be zoomed in to fit the screen, but sometimes the subtitles are cut off at the bottom - whereas a 16x9 disc places the subtitles within the frame - as opposed to below it.
    Does that make sense?
    If so, thanks in advance...
  2. Roger_R
    Roger_R Second Unit
    Nov 6, 2003
    372
    On the few DVDs I have that are not 16x9 enhanced, the text is always below the picture, making it impossible to do a full zoom without chopping off most of the text. Just another reason for not buying non-anamorphic DVDs I guess...
  3. Larry Schneider
    Larry Schneider Second Unit
    Aug 9, 1999
    356
    On a few discs this can be a problem; on my old Toshiba, there's a mode that moves the entire picture up so that the subtitles are there. Basically a 2.35 film is shown with no black bar on top. It remains a problem on 1.66 subtitled discs, like "Stalingrad." That, I watch in 1.33 mode.
  4. Tom Tsai
    Tom Tsai Supporting Actor
    Nov 13, 2002
    565
    ^ I too do that for 2.35 movies...but there's just no way around it for anything in 1.85 [​IMG]
  5. Ted Todorov
    Ted Todorov Cinematographer
    Aug 17, 2000
    2,965
    24
    I own neither film, however on 2.35:1 non-anamorphic DVDs (Yojimbo, Tokyo Drifter, etc.), Criterion puts the subs in the lower black bar.
    What works for me is that my Malata DVD player allows me to zoom in just the right amount, and the I can shift the picture upwards, cutting off the top black bar and leaving the bottom one with the subs on screen.
    If you have a lot of non-anamorphic DVDs, I strongly recommend getting a DVD player that has incremental zoom and X/Y positioning capabilities.
    Ted
  6. Randy A Salas
    Randy A Salas Screenwriter
    Apr 25, 2002
    1,348
    If the subtitles are player-generated, some players allow you to move them around on the screen. So you can zoom the image to fill your screen in the best way possible, and then move the subtitles up into the screen area. Obviously, you're out of luck if the titles are burned in.
  7. Daniel P
    Mar 1, 2002
    217
    Thanks guys...I'll keep my fingers crossed for 16x9 re-releases I guess...
  8. Mark_vdH
    Mark_vdH Screenwriter
    May 9, 2001
    1,035
    Criterion's Brazil (1.85:1) has its subtitles placed within the frame, as does Picnic At Hanging Rock (1.66:1). It seems Criterion wasn't very consistent regarding this, so maybe Amarcord and/or Rublev are okay after all....
    I have a player that always keeps the subtitles on screen when using the player's zoom function. However, the annoying thing is that it also keeps an ugly, large icon on screen when using the zoom function. Which means I have to use the TV's zoom after all.....
  9. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Mark,
    If that player is a JVC, you can usually make the zoom icon disappear by entering a non-existent chapter number or doing anything else that brings up the "operation prohibited" symbol (a 0 with a line thru it).
    On current JVC's the Zoom icon goes away by itself after a few seconds. They also have a 1.8 zoom as the lowest level which chops off less than the 2.0 zoom. Subtitles appear complete in the lower part of your set's screen, regardless of where they appear when not zoomed.
    I recently bought a JVC XVNA77SL (also in black as the XVNA70B) and it does a wonderful job with non-anamorphic widescreen dvds, as well as automatically pillarboxing 4/3 material. No more messing with the set's aspect ratio settings during special features.
  10. Mark_vdH
    May 9, 2001
    1,035
    Steve: I don't have a JVC player (a Cyberhome, which isn't my primary player), but tried it anyway. It didn't work, but thanks. [​IMG]
