jeff morris
- Nov 27, 2001
Greetings!
I just got a Nokia 8260. Its a little mini one, really nice! clear as a bell and works everywhere!
So I went out and bought a custom faceplate for it, but I can't get the original off. It just will not come off. No way Also, the entire phone seemed to 'come apart' as I was trying to remove the faceplate. The older phones, you just pulled it off with the button pad and -pop- the new one went on.
So I put it all back together as it was, it still works fine.
Can anybody suggest where I might be able to have this done? I certainly don't want to screwup an excellent product out of my own stupidity by breaking it.
jeff
jeff
