Gary-Bru
- Oct 6, 2002
i have an M&K, MX-70 subwoofer,and have been having some problems with, it makes noise through it ever while unplugged (RCA cables) so i know it's not coming from receiver. found the problem but dont know what to do about it's.. the min/max knob on the back.. if you just tap it while the woofer is making the noise it stop's. The subwoofer work very good..but after shutting down system it makes the low woofer noise and i have to tap knob for it to stop.. is my subwoofer on it's way out or is there a fix
