Noisy DVD Player
Discussion in 'Playback Devices' started by Sam Pat, Jul 2, 2003.
  1. Sam Pat
    Sam Pat Stunt Coordinator
    Jun 15, 2003
    118
    I have a Panny DVD-S35 and it tends to be selectively noisy.
    I don't have any problems with a slightly noisy player, but this one isn't consistently so.
    Say I pop in the same DVD, and let it start up a bunch of times. On some startups, it's quiet. On others it's noisy. Just a slightly loud whirring noise.
    No problems with visual quality, even when it's being noisy.
    Any ideas?
    Is this a sign of a problem about to occur, or should I just ignore it?
    Thanks!
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Moving parts "settle down" when they've run for a few minutes. My bedroom player, with its lighter chassis than the main-system's player, is noisy by comparison. I can hear the whirring of the motor and how it changes pitch when performing different functions (such as navigating menus and actually playing the disc).
    Unless you hear something really scary, such as a loud grinding noise, there's nothing to worry about here. But I wouldn't stop and restart the player several times in succession if I were you.
  3. Sam Pat
    Jun 15, 2003
    118
    Thanks for the response, Jack.
  4. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,446
    647
    My RP91 tends to be noisy sometimes too, dunno why. [​IMG]
