No Way to Buy a Sub...Help
Discussion in 'Speakers & Subwoofers' started by MitchS, Sep 9, 2005.
  1. MitchS
    MitchS Auditioning
    Mar 8, 2000
    7
    OK, not the smartest way to decide, I'll admit that up front. However, the priorities are 1) Size: 11 inches tall or less so that pretty much limits it to an 8" woofer, 2) Budget: stretched at $800, 3) Home theater = 90%, Music = 10%, 4) Speakers are in-wall and in ceiling Paradigms, so we're not talking hi end system here, and finally 5) 60 yr old ears.
    I've narrowed my choices to a Velodyne SPL800II or a Def Tech SuperCube III. The Velodyne is a discontinued model but availabe for $600 delivered. Best I've found for the Def Tech is $700 + shipping, but looks to have better specs. Worth $100 + more? Any other subs I should consider?
    Thanks in advance.
    MitchS
    near Lexington, KY
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    If you're other two dimensions aren't limited as much, and you have or have access to some basic wood working tools, have you considered a DIY option? $800 would go a long way to building a very impressive sub and with some mildly creative engineering wouldn't be difficult to use a 12 or 15 inch driver in a down or up firing configuration and still meet your height requirements.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Def Tech has these new in-wall subs that look extremely interesting. Would probably go well with your other in-wall speakers.
  4. MitchS
    MitchS Auditioning
    Mar 8, 2000
    7
    Got a second chance on a Sunfire Architectural on eBay for $500, so I took it.
    Thanks.
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    Nice...
