No Surrond Sound
Discussion in 'AV Receivers' started by Barry Ford, Mar 8, 2004.
  1. Barry Ford
    Barry Ford Extra
    Feb 11, 2004
    16
    Newbie question,
    In setting up my new Onkyo 601 receiver, I set speaker size and number, distance, crossover, db etc. no problem. The speakers sound fine on the test menu, but with DVD, VHS and TV sources, I get good front sound but no sound at all from the two surround speakers. I've tried both DTS and DOLBY on the DVD sound setup. I'm using composite cables from VHS and DVD.
    I've reviewed the receiver and DVD setup menus 'til I know them by heart and see nothing amiss.
    What am I missing?
  2. ChrisMcK
    ChrisMcK Stunt Coordinator
    Jan 9, 2003
    72
    How do you have your dvd player hooked up to the receiver? You need a digital interconnect, either a coax or toslink
  3. Chun Lam
    Chun Lam Agent
    Jan 20, 2004
    46
    There's your problem - if you want DD or DTS, you'll need to hook up your DVD player to your receiver using a digital output. Otherwise, all you'll get is stereo.
  4. Barry Ford
    Barry Ford Extra
    Feb 11, 2004
    16
    Thanks Chun,
    Glad I confessed to being a Newbie.[​IMG]
