no sound from TV
Discussion in 'Beginners, General Questions' started by JuanNarvaez, Dec 21, 2005.
  1. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    Hello guys help me out here. I just got my surround sound, I'm running a DVD player, a satellite receiver, and cable. I'm running a very simple connection. Videos to TV and audios to receiver. I can get sound from DVD, satellite receiver but when I just want to watch cable TV, I don't get sound on my surround sound. My receiver is a Kenwood VR-6070.
  2. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    Need more info, Juan.
    How is everything connected?
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    And are you saying that you simply don't get surround sound when watching cable? In other words, are you getting two-channel stereo? That's the way it defauts.
  4. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    2
    there's a little mode called Dolby Prologic II. Many stereo television programs are actually mixed in Dolby Surround.
  5. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    Ok like I said I just connected everything to make it work.
    Here's how I have it.
    sat signal--to sat rec.
    cable--to sat rec.-- and both of these go to TV by RG-6.
    DVD to TV by yellow RCA
    and I have sat receiver's and DVD player's audio by RCAs to receiver.
    I went to the newbies section and read some stuff from there and might help me out. As soon as I get home I will try to route all audio and video through the receiver. Still any ideas are welcomed.
  6. JeremyErwin
    Feb 11, 2001
    3,218
    2
    ah. now I see. does either your TV or your cable box have RCA outs?
  7. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    yes it does
  8. JeremyErwin
    Feb 11, 2001
    3,218
    2
    what model of TV is it?
  9. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    Model # I don't know but its a 32" TV with TV Guide. I bought it about 2 yrs ago.
  10. JeremyErwin
    Feb 11, 2001
    3,218
    2
    the kenwood receiver looks to have a video bandwidth of 10 Mhz, which is not really sufficient for 480p. If your TV can accept a 480p signal. you would probably be better off running any progressive component cables directly into the tv.
    As for sound from cable, you could string rcas from the cable box into the receiver, or from "tv audio out".
  11. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    You just got surround? Is the receiver Dolby digital or Dolby Pro Logic? If it's a Dolby Digital receiver, and you have your dvd player hooked up with rca cables for audio, all you'll get is Pro Logic surround (simulated surround), not true DD 5.1 surround. To get true 5.1 surround, you'll need to use a digital coax or optical cable, from dvd player to receiver's digital input for it.
    Then you'll need to go into receiver's setup menus, and assign the input you use for dvd, and digital audio output. You'll also need to make sure your dvd player is putting out a digital signal to receiver. In the dvd player's setup menus, set the audio output to "Bitstream", instead of PCM.
    The only way to get 5.1 surround from your sat or cable, is if you have a Dolby Digital sat receiver or Digital cable box, and subscribe to Premium Movie Service (HBO, Showtime, Starz, etc.). Otherwise, all you'll get is Pro Logic. Pro Logic isn't bad. Just not as good as DD 5.1 surround.
    Good luck! Keep us posted?
  12. JeremyErwin
    Feb 11, 2001
    3,218
    2
    the other way to get 5.1 sound is to get hdtv-- but that's another can of worms.
  13. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    I changed the settings on the TV and now I have sound, but its not yet DD 5.1. I went to Radio Shack to get a coaxial cable and they didn't have any, so I'm going to wait on that. Right now I have my receiver on Circle Surround II, how is that compared to DD 5.1 and Pro Logic? Also, my receiver has tow sub outputs, one in the section where you connect the DVD/6ch and the other one where it says pre outs. Is there a difference where I connect it?
  14. Ed Moxley
    May 25, 2003
    2,701
    Eastern NC
    Ed
    Connect a powered subwoofer in the "Pre Outs" area.
    You can get the digital coax cable at Wal Mart too. Or Best Buy, Circuit City, etc.........
    Not familiar with the Circle Surround II mode you mentioned. It sounds like another simulated surround mode though.
  15. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    Thanks a lot for the info everybody, like I said I just need to work of the Dolby Digital, but I least I got some sound.
  16. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Juan, also, have you checked your DVD player's audio-setup menu? Go in there and select Dolby Digital (and DTS) as your automatic defaults. Newcomers often miss this crucial step.
  17. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    They actually have plenty, they are called "video cables". Do not pay extra for a "Digital Coax" cable. Just buy any 75 ohm video cable, they are the same thing. In fact the SPDIF specification was specifically written to use a 75 ohm video cable for the connection. Then the marketing departments got ahold of it and figured out how to charge $50 for a $5 cable.
  18. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    I'm back with another question guys. Like I stated before, I'm running the video to the TV and audio to the receiver. I have the DVD player to the TV with a video cable(yellow RCA), I removed that and connected it with a s-vidoe cable and I don't get any video. Is there any settings I have to move or what I am doing wrong.
  19. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,410
    312
    9,110
    Cees Alons
    Juan,
    How do you select the S-Video input on your TV-set?
    Cees
  20. JuanNarvaez
    JuanNarvaez Agent
    Mar 11, 2004
    43
    That's why I was asking because I'm just plugging in the cable and press input on the remote untill it says "video" on the screen but the screen goes to unusable signal. The only options that my TV has are the video and front.
