no sound from rear speakers
Discussion in 'Archived Threads 2001-2004' started by Ben Cooper, Aug 2, 2001.
  1. Ben Cooper
    Ben Cooper Auditioning
    Aug 1, 2001
    2
    I just moved into an apt. and I'm trying to set up a very basic home theater system in the living room. I have an older Pioneer Dolby Pro-Logic receiver (model# VSX-453) that is hooked up to a RCA DVD player. The problem is that I can not get any sound from the rear speakers! I have turned the rear speaker sound volume up, as well as hooking the rear speakers up to the front to confirm that they weren't blown. I have the receiver in pro-logic mode, etc. because the two front speakers and the center channel works and I can get white noise from the front 3 channels in the test mode. I've checked all connections as well. Any ideas for troubleshooting this frustrating problem?!
    P.S. I tried a topic search on this but it didn't answer my question.
    -Thanks
    Ben
  2. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Did you set the receiver's rear speaker setting to YES? Some default to NO, until you tell it otherwise.
    Dan
    Stop HDCP and 5C-- Your rights are at risk!
  3. Tom Pielech
    Tom Pielech Extra
    Jan 26, 1999
    23
    May I also suggest you check out your DVD player's settings.
