no sound from my digital source
Discussion in 'Beginners, General Questions' started by steve___t, Apr 2, 2004.
  1. steve___t
    steve___t Auditioning
    Mar 16, 2004
    8
    i just bought a new stereo and when i hook it up with my coxial cable there is no sound. it only plays with the analog cables. my dvd play is old and was cheap to begin with.....can my reciever not process the signal coming from the dvd player....or is my cable defective?
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    do you mean the digital connection from the dvd player to the receiver? it's possible you may have to "assign" a digital connection to a particular input.
    list your gear and how you currently have stuff hooked up. that will help us help you. [​IMG]
  3. steve___t
    Mar 16, 2004
    8
    dvd player : apex ad-660
    cable: interlink datalink100
    yamaha htr - 5660
    on the back of my dvd player i pluged the cable in the the pcm/bitstream coaxial port.....i connected the other end to the digital in cd connector on my receiver (it is the only coaxial one i have on my receiver)
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I believe that is your problem.
    There are 2 different types of digital signals:
    - PCM (Pulse Code Modulation) provided by CD players
    - Dolby Digital provided by DVD players
    Your reciever has a digital-input for a "CD" player so my guess is it only can handle PCM signals.
    That receiver is listed as a DD/DTS unit. You need to find the other coaxial-digital connection that is attached to the DVD player input.
  5. steve___t
    Mar 16, 2004
    8
    thanks a lot
  6. Bob McElfresh
    May 22, 1999
    5,182
    I thought of something else last night:
    My Yamaha has a setup menu for the coaxial-digital input. It has 3 settings you can toggle between: PCM, DD, AUTO. You should pick "AUTO" for auto-detect. My guess is you may have the receiver set to "PCM" so it wont recognize the Dolby Digital signals.
    Let us know what works.
  7. steve___t
    Mar 16, 2004
    8
    still can't get it....i have it set to auto and i assigned the input to the dvd player....do you think it might be a problem with the cable?
  8. steve___t
    Mar 16, 2004
    8
    thanks for the help.
    there was a setting on my dvd player for audio output....i had it selected to analog.....
    again i appreciate the help
  9. Bob McElfresh
    May 22, 1999
    5,182
    Duhhhhh... I should have suggested you check this as well. [​IMG] Glad it's working.
