Mark_R
- Sep 12, 2001
I have an Onkyo 787 and it doesn't have a problem. I think I did wind up w/ a bad amp that will have to be replaced, but before it went AWOL it was sounding awesome.
BetterCables connect to input 1 on the S1000 (in stereo mode)
I believe the fix is simple in your case. Move the input to #2 when you use the stereo position of the Samson. If you use input #1, the switch must be in parallel (and, you're ready to add a 2nd SVS to input #2 as well!)
This is what I found on my S700 when trying to sort out Conrad's equipment problems.
the volume on the amp is turned up halfway.
Amp volume should be all the way up. This is not a volume knob- it is an input gain. If you lower it, you raise the amount of voltage needed to get the amp going.
I don't trust an amplifier's input pad, and don't use it unless I absolutely have to! So, I would use the amp with the input knobs turned WIDE OPEN, and let your preamp have control.
If you find that you cannot possibly get your Preamp sub output backed off enough to allow you to get everything even, then consider lowering the amp input knobs. But if my Preamp could dial in calibrated level with the amp's inputs WIDE OPEN, I would absolutley run it that way!
Don't run the amp at 1/2 input and then complain that you're not getting level. This is not an ouput knob, it regulates how much level you are putting INTO the amplifier!!!!!
What I find funny is that some of you have calibrated with the same tones, and the same target levels- and them complain the new subs aren't louder. They shouldn't be louder.
-Vince
Depends on the design of the amp- and some "consumer" home theater amps are designed differently. The question is what the control can/is doing.If you can get ref level calibration said:Quote:
