I have just taken delivery of a paradigm servo 15 sub. tested worked well. have just swithced off sub and heard a big pop. I then moved the sub to the other side of the romm and the power will not come on the sub- what do i do? I have checked fuse on the plug and it is fine- i haVE ALSO TRIED SWAPPING POER SUPLLIES NO JOY. Can anyone please offer my some advice- should i send it back?
Thank you in advance
See if there's a blown fuse (easily accessible from the back, possibly covered by a plastic cap). Maybe it's a simple blown fuse, which you can cheaply replace. If it keeps blowing fuses, however, it should be returned.
Since you say you checked the fuse, and you heard a "pop", I would say there is a good chance the amp is toast. Something in the circuitry is fried. I would get your dealer involved quick.
Thank you for your posts . I have checked on the rear of the sub and there is no visible sign of a fuse. It is all sealed and accessible only by unscrewing the back cover. I think i will leave this alone and return it to the dealer.
