Ryan Peddle
- Nov 28, 1999
After reading RAF's essay on components in the home theater world and read a few other posts about stand alone decoders for Dolby TrueHD and what not I started thinking about my AVR. My Yammy HTR5860. Simple and effective receiver. But all I have going to it is and Optical cable from my upscalling dvd player, and a coax cable from my HD digital cable. ALL my video (HDMI and component) goes straight to my projector. Hell, even when I had my Xbox it was optical and component. As would be when I pick up a 360.
So whay do I need a receiver or even a PrePro filled with useless inputs? In an all digital world, for me, I don't need any compostie video, Svideo, or two channel audio.
Now I know there are a lot of people out there that use some of these connections. But I do not. And I bet there are a lot of other people out there that don't use them either.
So my proposition is that in a setup where you are only using HDMI and Component for video, and Optical/Coax/5.1/7.1 analog for audio, why can't there be a dedicated audio decoder for DD, DTS, DPLII (and any other DSP you might want) as well as DD+, Dolby TrueHD, DTS MasterHD and PCM, from there use preouts to a 5.1 or 7.1 dedicated amplifier, and then to your speakers. And the video side can go to a dedicated vid pro and then to you display/projector.
In this scenario I would be eliminating all the electronic connections that I do not require, saving a lot of space and probably improving the overall quality dramatically.
Does anybody remember with Prologic receivers were the norm and when DD/DTS came out you could be an outboard decoder (Technics) to do that processing. Well that is the direction I would like to go. Why can't we have this?
Discuss.
(BTW, If this needs to be moved to a more appropriate section, please do.)
Discuss.
