Jon_Are
- Jun 25, 2001
Here's my situation: I get stereo audio from a television broadcast when using the built-in TV speakers, but if I switch it to my receiver - and external R & L speakers, only the right speaker works; there is no sound from the left.
Using PS2 works the same way...both TV speakers work fine, but if routed through the receiver to the external speakers, there is no audio from the left.
I have no audio problems whatsoever with DVDs and 5.1 sound, or CD or FM audio; all speakers work properly.
What I'd like is some step-by-step troubleshooting advice, spelling out for me step one, step two, etc. In other words, I'm looking for a "do this, if that doesn't work then do this, if that doesn't work do this..." scenario.
Thanks a ton,
Jon
Thanks a ton,
Jon
