B&K menu - speakers are set to: Front - Small THX Center - Small THX Surround - Small THX Side - None Sub - Yes THX THX Ult2 - Yes THX
Denon DVD 3800 Audio settings: Audio Channel - Multi Enabled (Multi or 2 Channel) Digital Out - Normal Enabled (Normal or PCM) Bass Enhancer 2 channel - OFF (OFF or ON)
I have both optical and DVD-A interconnects hooked up to the B&K 50. I have no bass signal when I play a DTS or DD5.1 DVD. When I change the sound field to THX Ultra, DD, DTS, Stereo, Mono etc.. the bass kicks in instantly. As soon as I enable DVD Audio the bass signal shuts off. The bass indictaor light shuts off the second I enable DVDA sound on my Bass (Crown K1)amp.
