I see someone finally figured out that window mystery where everyone used to just cheat through.
77 FIRE EXIT WINDOW 77 --------------------------------------------------------------------- MOVE: down (68) PUZ : select up, right, up, left, up, right, right, down, right VID : 1 - [505]
This is a labyrinth within the labyrinth. There are twelve selectable diamonds in the window, arranged like this:
Using the arrow keys on your remote, you must navigate your way through these diamonds. One wrong turn will send you back to start (represented by the up arrow at the bottom of the screen). Upon entering the room, push up, right, up, left, up, right, right, down, right. There is no need to push the remote's enter key; after completing the final move, the movie will automatically start. Your path will look like this:
5 6 7 *
4 3 8 9
1 2 * *
If you'd like to cheat, you can also push "20" on your DVD remote (or, if you lack the "20" key, press "+10" twice, then "0").
