Dave F
- May 15, 1999
Linksys has a new wireless adapter, the WGA11B, which they are marketing towards the gamer market. It functions similar to the wet11 bridge, but this is driverless, yet still supports WEP. (If you use wep, you need to initially hook it up to a wired network, & run a utility which stores the settings on the adapter)
I just picked one up for a ReplayTV unit, and it works pretty slick. The box says that even without a WAP, you could use two of them to function like a crossover cable. So... you could buy 2 and hook them up to consoles like a system link.
-Dave
-Dave
