I have a 10/100 NIC card in my system now and I was wondering if I should be able to swap this out with a 10/100/1000 NIC with no problems. What do I want to get? I have seen that they average around $29 for one but then they also run up to $100 for what appears to be the same card from the same company. Why the difference in price?
I am maxing out at the 100 Mbits/sec through my cable modem and they have speeds up to 500 Mbits/sec available through the modem. My next question is if I get a 10/100/1000 NIC and replace my existing one will I be able to get the max bit rate through this new card at whatever the cable modem can deliver or are there other limiting factors?
I have an HP PC that is hooked up through a Linksys router hub to my cable modem.
Any info on these would be appreciated.
