NHT SB-3 questions (1 Viewer)
Todd Mayo
Would 5 NHT SB-3 speakers be the best choice for complete system synergy, or 4 and a center channel?
I can't access their site. I'm not sure what center is the 'match' anyways.
Elinor
For seamless multichannel presentation, 5 of the same. Is the SB3 shielded? ... would this be an issue if it isn't?
ScottHH
www.nhthifi.com is up now.
NHT says that the Sc-2 "While designed to sonically match the tonality of all SuperAudio models, this model is ideal to mate with the SB3 bookshelf and ST4 tower systems. Its compact size and magnetic shielding permit easy placement on or near television monitors."
John Garcia
NorCal
The advantage of the center is higher sensitivity. It's a decent center and I wouldn't say there is a reason not to get one. Not sure how hard it would be to get a single SB-3. My dealer sells them only in pairs.
andriesprice
