News To Me: Optical Inferior to Coax: Except Glass...
Discussion in 'AV Receivers' started by Arthur S, Aug 21, 2005.
  1. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    A serious player on another Forum said that optical is inferior to coax because it has to go through another process.
    The discussion then went on to say that if you use an optical cable that is made of real glass strands (as opposed to the ordinary plastic strands), optical is as good as coax.
    This is all news to me.
    What do you think?
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,186
    44
    1,610
    Central FL
    Phil
    This has been covered many times and there's probably somehing about it here: http://www.hometheaterforum.com/htfo...hreadid=120328
    Do a search. Dolby Digital signals are delivered in packets so I'd be hard pressed to think that there really can be much if any in the way of differences. With 2 channel PCM on a CD, optical cables can induce more jitter but are not prone to RFI or EMI like a coax cable. So the answer might not be the same for every situation.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I have come across similar arguments:
    1) Coax is better because it does have higher bandwidth (data rate capacity).
    2) Coax is better because optical has extra conversions (optical to electrical to optical to electrical), and is therefore more likely to have higher induced jitter.
    3) No RF/EMI interference for optical. (But coax is 75 ohm shielded coaxial cable, anyway.)
    I have used both with no complaints, but I always default to coax if I have a choice.
  4. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    2
    Using optical is often the simplest way to eliminate ground loops
  5. Phil A
    Phil A Producer
    Oct 1, 2000
    3,186
    44
    1,610
    Central FL
    Phil
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    So what? Does the serious player understand that the data on CD's is interleaved to begin with and needs to be reconstructed before it gets processed by the DAC? If there are bad conversions you'll have data loss that can't be reconstructed and then have dropouts. What you will find though between the two flavors though is that levels might be different and that in itself can lead to perceived sound quality differences. I'm sure such a serious player has taken the time to measure the output levels using test tones and a VOM, right?
    There are less attenuation losses with glass as opposed to plastic, but that's only an issue if you're running very long lengths. Glass, though, does give you bragging rights. Comparatively inexpensive glass toslink can be found at MCM.
    What do you think?
    Use the type of connection that best meets your needs or potentially addresses a problem. The serious player probably needs to go out and laid more often. Maybe it'll clean out his ears.
  7. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I prefer coax simply because I know it's not going to get knocked out of the socket. [​IMG]
  8. Kevin C Brown
    Aug 3, 2000
    5,712
    It won't get "broken" either. Coax cables are much more robust than optical. One other problem with optical, is that you can get dust in the connectors which can kill the signal.
    Good point about ground loops. [​IMG] But more than likely, if you have a ground loop from cable TV or a satellite connected up wrong, changing just the connection from the DVD player to the receiver or pre/pro isn't going to fix the problem.
  9. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    I keep hearing about how the the coax is more robust and has tighter connection.
    I don't see how that makes any difference to most people at all.Unless you move equipments in and out like a reviewer from it's place therefore unplug things often, or just like to play with your cable like a lasso[sp?], it shouldn't make any difference how beefed up the connection or the cable is.
  10. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,461
    338
    9,110
    Cees Alons
    Millions of yards of optical fiber connections are used in offices, across the country, buried beneath your streets, etc. for the Internet as well as cable transmissions.
    What do you think? They are all inferior?
    Truth is: fiber connections between AV-modules are so short, as compared to all other professional use, that the chance of losing even one packet of data is virtually zero. This includes the conversion to and from light. Glass or plastic.
    When used for digital audio, they're electronically at least as good as coax. And I wonder about mechanically. Sure glass can break. But so can metal strands and soldered connections.
    Cees
    PS: Do I count as a "serious player" on this here forum? [​IMG]
    C.
  11. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    It depends on the quality of the connectors on the end of the cables. I've used optical cables that just don't "click" into their little socket and have had them pop out too easily when just moving the HD box slightly. Yes, it only happens when you move the unit, but that's still not good enough for me.
  12. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,950
    28
    1,610
    Arthur,
    Would this be the thread:
    http://www.stevehoffman.tv/forums/sh...ad.php?t=58991
    I like Hoffman's music forum, and do read the hardware stuff, but there really seem to be a lot of "true believers" that really push the credibility envelope. Not quite as many as at Audio Asylum, but you can't swing a dead cat without hitting someone in the head that thinks his new $500 interconnect is da bomb.
    Good comment there Chu....I notice that my 2CH system always sounds better after the misses and I get busy![​IMG]
    Brian
  13. John S
    John S Producer
    Nov 4, 2003
    5,460
    I like opitcal better because the little red light is cool.... Otherwise just use the convienient connection of your choice... [​IMG]
  14. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    You do to me, Cees. [​IMG]
    Use whatever is convenient and cheap. It doesn't matter.
  15. Cees Alons
    Jul 31, 1997
    19,461
    338
    9,110
    Cees Alons
    And that's reciprocal, Philip! [​IMG]
    Cees
  16. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Tom Nousaine once conducted a test where he had several converters chained together and people, under controlled, level matched, and unsighted conditions were unable to differentiate between the chained setup and a straight through output. Of course one can argue that the system wasn't revealing enough, the listeners were unfamiliar with either the music or the setup, the moon was in Scorpio, they were stressed...the usual suspects [​IMG]
  17. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    *LOL* I wonder what the system sounds like if you do get a hit... ;D
  18. Lewis Besze
    Jul 28, 1999
    3,134
    Yeah it supposed to click if it doesn't then it's "broke", and shouldn't be used at all. My comment was for good functional connections.
