Newcastle R-956 Question
Discussion in 'Archived Threads 2001-2004' started by Dan Cabral, Jul 2, 2002.
  1. Dan Cabral
    Dan Cabral Stunt Coordinator
    Jun 26, 2002
    69
    I have a Newcastle R-956 AVR that I'm having a problem with that I can't seem to figure out.
    I'm using a JVC XV-FA95GD for DVDs and DVD-A. I have it hooked up to the R-956 via Optical for movies and CDs, and for DVD-A, I have the analog outs on the JVC going to the Direct 6.1 inputs on the AVR.
    For video, I have a component hookup to my 27" Wega.
    Now, movies and CDs play fine. When I play a DVD-A or MP3-CD disc and switch to the Direct 6.1 playback on the AVR, I get no video. This is somewhat disconcerting since the MP3-CD playlist is only displayed on the screen, and the various DVD-A video stills would be nice to be able to see.
    If I switch back to Video 2 playback on the AVR, I do get video, but no audio on DVD-A or MP3-CD discs.
    Any ideas on how I can get video to appear on my monitor when using the Direct 6.1 selection for audio playback?
  2. Dan Cabral
    Jun 26, 2002
    69
    C'mon... someone's gotta know. [​IMG]
  3. Ed Haze
    Ed Haze Agent
    Mar 16, 2002
    40
    Did you try using the OSD? If it is like the 863, you can change the video input selector without changing the audio source. Just a possibility.
  4. Dan Cabral
    Jun 26, 2002
    69
    I think I realized the problem...
    When I had it set to Direct 6.1, it showed the video source as 6. I didn't recall seeing a Video 6 input on the back, so I checked the manual, and sure enough, there's a composite and S-video input for "6.1" (very poorly labeled and positioned, I might add).
    The reason I'm unable to view it in this manner is because I'm ONLY using the component hookup.
    And I kinda went without using the OSD because it won't go over the component video output, only over composite and S-video.
    Looks like I'll not only be moving my DVD component out away from the AVR and directly into the TV, but I might also now have to get an S-Video hookup to go from the AVR into the TV so I can take advantage of the OSD.
