Newby with a Pioneer VSX-47TX question
Discussion in 'AV Receivers' started by George Poynter, Sep 6, 2004.
  1. George Poynter
    George Poynter Auditioning
    Sep 6, 2004
    4
    My reciever will support the THX seven speaker system ( curently using the conventional 5.1, 5 speaker set-up). Can I add two more speakers and will the two L/R & two R/R's produce sound in the 5.1 mode? If not how can I make this happen with a seven speaker system? Thanks in advance.
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    Yes and yes. There is a mode that allows you to activate the rear surrounds with 5.1 material. When I had a Pioneer I used it almost exclusively.
    DJ
  3. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    THX Surround EX. [​IMG]
  4. Scott Merryfield
    Dec 16, 1998
    12,309
    1,066
    9,110
    You can also use the THX Ultra 2 mode to extract rear center channel information from 5.1 soundtracks. I use this mode quite often on my 47TX. Also, Neo:6 will extract rear center information from Dolby Surround (two-channel matrix) encoded material -- sort of a 7.1 version of Dolby Pro Logic II. Dolby now has Pro Logic IIx which does the same thing, but that format is not available on the 47TX.
