Newbie - Vented Shiva with PE 300-796
Discussion in 'Archived Threads 2001-2004' started by Forrest, Feb 20, 2003.
  1. Forrest
    Forrest Auditioning
    Oct 20, 2002
    7
    I have been reading this forum for a number of months and have decided to take the plunge and build a ported Adire Alignment Shiva tuned to 20 Hz. A few weeks ago, I bought the PE 300-796 amplifier as it was on sale for $100.
    I have built the box and am about to install the amplifier, but before I do, I would like to modify R26 and R27 to tweak for my set-up.
    What dB of bass boost should I modify the amplifier for a vented 85l box tuned to 20Hz?
    Thanks in advance,
    Forrest
    PS the 300-796 is apparently the same as the 300-794 except for a 6dB bass boost at 30 Hz
  2. Andrus_R
    Andrus_R Stunt Coordinator
    Oct 19, 2002
    109
    No clue what yer talking about [​IMG] but mine has bypass switches to disable Bboost. Vendor rec me 1db boost around 25 hz for my sbb4 temp design. I've yet to start[​IMG] coz i broke my mid finger on the day i was gonna start [​IMG] [​IMG] .
    Ohh the irony. [​IMG]
  3. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    Forrest, the amp should have shipped with the values of resistors you need to replace to eliminate the boost. With that design, I highly doubt you'd want any boost anyway. It'll be quite loud and go quite low! Believe me!!
  4. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    876
    I'd probably go with the no-boost values that the 300-794 uses:
    R27=120k
    R26=56k
    This will give you a cutoff frequency of 19.4Hz for the rumble filter. That should work well with a tuning frequency of 20Hz. You won't have to worry about subsonics bottoming your woofer. I've built a spreadsheet to determine resistor values for any boost/frequency combination and I'll be happy to run some numbers if you decide you want something specific.
  5. Forrest
    Forrest Auditioning
    Oct 20, 2002
    7
