BrettL
- Jan 9, 2004
Quick computer stats:
*OS: XP Home (SP2)
*Pentium 4: 3.00 GHz
*2 GB of Ram
*Monitors: (Just ordered) Dell UltraSharp 2407WFP 24-inch Widescreen Flat Panel LCD Monitor (w/ DVI-D) & currently using 17 inch CRT
*Sound Card: SoundBlaster Audigy
*Speakers: Not worth mentioning
I just replaced the power supply in my computer in anticipation of adding a new graphics card. I replaced my 250W with a BFG 650W with dual PCI Express Connectors and Dual 12V rails. This is probably more power than I need but I figured what the heck. My current video card is a nVidia GeForce FX 5200 AGP and I am thinking of switching to the ATI All-In-Wonder X800 XT Video Card, 8x AGP, 256MB DDR (I have 3 PCI slots, but I'm not sure if they are PCI Express so I think I'm going with an AGP card). I'm hoping to be able to watch TV and play games on the Dell 24 inch LCD Monitor and work on applications on the 17 inch CRT at the same time. The ATI All-In-Wonder has a DVI-I out but I've searched and there appears to be an adaptor that will allow me to connect the ATI All-In-Wonder (DVI-I) to the Dell 24 inch LCD Monitor (DVI-D). So here are my questions:
1: Will I be able to watch HDTV with the proposed setup? (I have Charter HD)
2: Will I be able to use both monitors at the same time with the ATI All-In-Wonder?
3: Should I get a separate video card and TV tuner for better performance?
4: How can I tell if a have a mothorboard that supports PCI express?
Sorry for all of the questions, but I don't won't to buy a bunch of components that will not achieve the desired effect. I'll hold off on the sound card and speaker questions until later.
Any comments are welcome, Thanks.
*OS: XP Home (SP2)
*2 GB of Ram
