rafayel
- Jun 25, 2002
Hi I just bought a home theater system and I bought a surround sound speaker mount, should I mount my 45 watt each surround speakers on the wall in the back or should I mount it on the ceiling (which would yield better results)
One more question I bought a pair of monster xp speaker cables to replace my cheap speaker cable on my front speakers but I have a problem the old speaker cable wont come off it seems to be glued should I cut half of it off and twist the new monster cable together with the old speaker cable or should I just leave it alone
Thank you for your reply
