roger sandifer
- Jan 27, 2004
I just received my new receiver (JVC RX-DP20VBK)and I was reading about connecting the speakers and ran into a problem. It says that when connecting to both front 1 and front 2, use speakers with 8 ohm to 16 ohm impedance. When connecting to either front 1 or front 2 use speakers with 4 ohm to 16 ohm impedance. I have a pair of Infinity SM-102 speakers rated for an 8 ohm impedance. Does this mean that I will only be able to hook up my speakers if I go out and buy another pair to hook to the front 2? or when it says 4 to 16 ohms, does that mean 4 through 16? and a 8 ohm speaker would work only using the front 1 terminals. Thanks for your help
