Newbie question about connecting speakers.
Discussion in 'Archived Threads 2001-2004' started by Jason Bell, Apr 7, 2002.
  1. Jason Bell
    Jason Bell Stunt Coordinator
    Apr 3, 2002
    175
    Whats the best way to connect speakers to the binding posts.
    Bare wire, Banana plugs, etc. Sorry for such a basic question but everything I've owned up till now has just had the old spring clips.
  2. Paul_Fisher
    Paul_Fisher Screenwriter
    Dec 27, 2001
    1,219
    I find it easiest to just put the bare wire into the binding posts. But thats just me [​IMG]
  3. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    If you tend to swap receivers in and out on a frequent basis, banana plugs are about the most efficient implementation to use. However, as the previous poster stated, connecting the bare wires is also fine - provided you don't need to rearrange these connections on a frequent basis. There are others who also prefer the bare wire route, but they will "tin" the ends of the wire with solder to keep the wires together and make a good connection.
  4. Jason Bell
    Apr 3, 2002
    175
    Thanks For the Replies.
  5. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
    If you use 12 awg or larger; Houston we have problems. It can be done direct with a little work and several checks that they are really tight. 6/8 awg banana plugs are large enough to allow you to insert the wire from the back or side for clearance behind your rcvr and ease of installation. Go to parts express.com and check out the 091-1260 24k gold plugs. I bought these and they fit great.[​IMG]
  6. Jason Bell
    Apr 3, 2002
    175
    Thanks Earl I'm gonna go check these out.
