EYESPORTS
- Feb 4, 2005
- Bruce
Looking for speaker advice and appreciate your input. We are undergoing new construction (using a Denon 3805 receiver) and looking to install speakers (7.1) for the family room which is 25 ft wide by 22 ft depth. Having an entertainment center - couch, love seat. I am looking for advice on speakers. Please keep in mind that my better half (wife of course) would like "invisible" speakers - so the smaller, the better. I'm going to surround with 3 in front, 2 at sides, 2 in back and a sub-woofer. Would really like to spend up to $1200 total - but need to look into this ASAP - as the builder is rushing me so he can prep the installation area. We are using 14-4 wiring - I'm looking for (1) advice on brands/models. I know to stay away from Bose (great marketers), but they certainly have the size speakers we're looking for (Will Not Use Though). I'm going to mount the speakers on the walls (brackets) at sides and back (the back 4). (2) Bipole or Dipole ? ?, (3) any special cable to run in wall for Subwoofer (?coaxial? - if so, what should the termination jack be on both sides - RCA?), (3) I (my wife) would LOVE in wall speakers, so if anyone can convince me with a model, I would. (4) For the speaker terminations, would you have the jacks with banana plugs? (5) I have looked at Klipsch Synergy (wall mounted), but don't know much. It's very difficult listening in a home theatre place - because almost everything sounds perfect (We're not audiophiles though) - Appreciate your input.
