RaymondSH
- Dec 9, 2003
Alright -- I need expert help PLEASE! I am setting up my home theater for the first time and am completely baffled on speaker setup due to the shape of my room. It is 17x11x8, carpeted with plaster walls. I can email anyone a sketch if that makes it easier ( I couldn't get it to load.....).
My problem is that the TV is off center from the main viewing area. Imagine sitting on a couch with a fireplace directly in front of you and the TV being off to the left. I had considered mounting the speakers in the corners, angling towards the center of the room. Is that my best choice or can you think of something else?
Any help will be greatly appreciated!
Thanks!
Ray
Thanks!
Ray
