Newbie needs help with his new Panny 53wx42
Discussion in 'Archived Threads 2001-2004' started by Paul Ennis, Aug 6, 2002.
  1. Paul Ennis
    Paul Ennis Auditioning
    Aug 6, 2002
    Hello all and thanks in advance for any help you can offer.
    I bought the new Panny 53wx42 this Sunday and brought it home with the help of a friend. Did the convergence 1 and 2 and tweaked all the other adjustments to my eye. I turned the SVM off. Anyway, here are my questions:
    1. It is pretty much unwatchable with the brightness turned below 38 or so, very dark.......Why? Is this a big problem? If I turn it and contrast down then I have too dark a picture as well as any shadows are pitch black.
    2. I have the color down to 12 or so, very low I would think??
    3. It looks incredible with a DVD (after adjustments mentioned under 1 and 2 above). I have cable (non-digital). I have to adjust tint with every channel change it seems and some channels just look cruddy overall, others i can get it looking really good. I never noticed any of this with my 27"...well, other than some had a crisper appearence than others. Is this the TV or cable feed? Would digital cable fix it?
    4. Would the AVia disc fix some of this?
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    You might have good luck looking/asking at panny.tv:
    Panny
    They specialize in Panasonic RPTV's.
  3. Steve_Tk
    Steve_Tk Cinematographer
    Apr 30, 2002
    2,833
    How bright is the room your tv is in?
  4. Josh Lowe
    Josh Lowe Screenwriter
    Jun 19, 2002
    1,063
