jonrice
- Oct 16, 2006
- jonrice
Hello everyone my first post hoping for some help info and advise.
I have a pair of fairly old JBL control 5 which have been standing for about 2 years doing nothing (the outer foam was gone).so I decided to try and repair them myself so far so good BUT then I realize the tweeters are not working,weird and its both of them. I have tryed the following.
using the driver connections to power them did not work.
using a direct out from my amp did not work.
I dont think the cross over's are broken because when I use the tweeter connection on the driver (bass speaker) I get some noise.
can both of them be blown or what I'm I little confused I'm really hoping someone can help as I'm on a budget and cant really afford to bye a new pair.
are thay easy to repair.?
thanks for reading,jon.
I have many more question but I'll start with this one.
cheers
cheers
