Newbie looking for some simple help
Discussion in 'Beginners, General Questions' started by Clark Bradley, May 3, 2004.
  1. Clark Bradley
    Clark Bradley Stunt Coordinator
    May 2, 2004
    58
    I bought some binding posts to cleanly install my system. What banana clip/plug do I use to hook the speaker wire into the front of the binding post (like plugging into a wall outlet)?
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    umm...not sure what you're asking. are you saying you bought some binding posts ... *or* ... banana plugs? the banana plug go into the big hole in the binding post.
    do you have links or pictures to what you're trying to do?
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I think he got wall-plate binding posts it sounds like. In which case you can probably use any connection method you want on them.
  4. Rex Overbey
    Rex Overbey Auditioning
    Apr 27, 2004
    7
    Yes you just plug them into the receiver like an electrical outlet. Usually they are a little snug so you have to push with a little force.
  5. Clark Bradley
    May 2, 2004
    58
    Sorry, can't post pics until I have 15 posts.[​IMG]
    I got the pins and plugs I ordered today and it was the banana plugs I was looking for. The posts I bought can be unscrewed to hold a pin or you can put a plug straight in (like an electrical socket).
    Thanks!
