Howie A
- Dec 22, 2002
I have been shopping for a new big screen HDTV. It looked like I was going to pick up a Mitsubishi WS-55511
(http://www.mitsubishi-tv.com/WS55511.html ).
But after taking a closer look it seems to me that it wont display in 720p, I was just wondering how often this format was used? I am not sure but, if the set can not display this format is there some sort of conversion it might do to compensate allowing me to view it at a lesser quality?
Also this set comes with a HD tuner I am not really sure if I fully understand what this means? I only have regular cable coming into my apartment (cablevision N.Y.) and don't plan on upgrading as of yet. But is there some sort of antenna I can buy in order to receive a HD signal? Someone I spoke to mentioned a Gemini something or other...
Any input on this set and/or opinions will be very helpful.
I just feel like its a SIN to turn down this deal..
Are You Ready For This......
(I feel this is a great deal tell me if I am just gullible.)
The set was listed in this weeks newspaper in
P.C. Richards ad for $2,999.97 and a buddy of mine
quoted me a price of $1,899.97!!!
To just make this a no brainier that saves me $1100.00
How did I even leave the store right?
Thanks Guys
Thanks Guys
