Michael Cook
- Dec 25, 2001
My father in law gave me a Pioneer vsx-509s receiver and Harmon Kardon KKTS-2 speakers for X-mas and it is much better than what I currently have (nothing)! Here is what I have now:
Pioneer vsx-590s
HK HKTS-2
36" Wega 36fv16
RCA Direct Tv receiver (forgot model #: d420?)
Samsung 709 dvd player (old, but does the job)
2 old vcrs (no s-video connections)
PS2
1. The Wega has so many connections on the back. It has a monitor out and audio out. All I have to do for the TV is hook a s-video cable from the tv to the TV monitor jack on the reciever?? NO audio cables? Is that the best way to do it?
2. The DVD player has a coaxial digital cable jack on the back. I hook this up to the receiver too, but is that the only wire I need to hook up for the dvd player?
3. For our play back vcr, I see a 'vcr in' and 'vcr out' on the receiver. Now, do I run the A/V cable from the input and out put on the vcr to the receiver? How would I go about hooking up 2 vcrs. I only see 1 set of in/outs for a vcr. Would I go from the output on the receiver to the input of the first vcr, then output of the first vcr to the input on the second vcr and then from the output on the second vcr back to the input on the receiver??
4. I have several s-video plugs. WHat I need so far is a sub woofer cable, coaxial digital cable, and lots of 12 guage speaker wire. Are there any other special cables I might need? Also, where is the best place to buy these cables?
5. Where do I hook up the playstation 2?? I have a monster cable s-video wire for the PS2, but I don't think I will be able to use that anymore since I will be using the s-video jack on the tv to go to the receiver. Is there anyway to hook the ps2 to the receiver. If I don't hook it up to the receiver, The sound won't come through the speakers?
Once I get all my materials and start to hook everything up, I will post a picture of our living room so I can get some advice on speaker placement, stands or wall mount etc. I need a good in-expensive audio rack too. I saw some plans on this site for one. I think it was called a flexi or something similar. Anyone build one of these? Are you happy with it?
Thanks for any tips or advice you can give me. I really appreciate it, and I have a bad feeling this is a start to a very addicting and expensive hobby!!
Mike
Pioneer vsx-590s
HK HKTS-2
36" Wega 36fv16
PS2
Mike
