Newbie Home Theater Setup for 14x14 Media Room (Pre-wired) (1 Viewer)
ponkarthik87
Pon Karthik Ponraj
Hi all,
I'm setting up my first home theater in a 14x14 ft media room with a 9 ft ceiling. The room is pre-wired for in-wall front 2 speakers, top 4 speakers, and a projector. My primary use is watching movies, and I prefer a projector-based setup. My budget is around $6,000 but can stretch up to $8,000 if needed.
I’d appreciate your guidance on the following:
  1. Screen Recommendations
    • What screen size would work best for my room dimensions?
    • Which are the best screens currently available in this budget range?
  2. Projector Suggestions
    • Which projector would be a good fit for my room and offer excellent movie-watching quality?
  3. Speaker Setup
    • With my pre-wired setup (front 2 and top 4 speakers), would it be better to go with a 5.1.4, 7.2, or another configuration?
    • Any recommendations for a high-quality speaker system?
  4. Receiver Suggestions
    • What receiver would work well for this setup?
  5. Subwoofer Advice
    • Should I purchase the subwoofer separately? If yes, which one would you recommend for this room size and budget?
Thanks in advance for your help and suggestions! Looking forward to your advice to make this a great experience.
