Newbie help with PB12
Discussion in 'Archived Threads 2001-2004' started by Don Morrison, Jul 9, 2002.
  1. Don Morrison
    Don Morrison Agent
    Jul 1, 2002
    28
    I just bought a JBL PB12 and am wondering what is the best way to hook it up? DO I need to go buy some cables for it? I have a Denon 2802 driving it, and also the JBL NSP1 system. (I have just recently aquired these things...I am very excited!!) In any case. It has the posts in teh back and the LFE stuff. Being new to this, what do I need to do?
    Thank you for your patience with me and thanks for your help!
  2. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    Dan, you can use any old audio/video RCA type cable if you have some lying around. Connect it from the subwoofer output of your receiver into the LFE input of the sub. In your receiver menu, set your speakers (front, center, rear) to "small" to reroute bass signals from them to the subwoofer. That should work.
  3. WilliamG
    WilliamG Supporting Actor
    Aug 6, 2001
    510
    Hi Don-
    I have the same speakers and sub that you do, and have had mine up and running for about a month now! I LOVE 'em! .. and you will, too[​IMG]
    The only thing that I would add is to get a dual RCA cable w/a "Y" adapter. Radio Shack has it. Plug both ends into the line level in LFE input of your sub and connect the "Y" adapter to the other end and then into the Subwoofer Output/LFE of your receiver. Of course, if you happen to have some around the house, they should do.
    Good Luck!
