Newbie help on Composite or S Video
Discussion in 'Archived Threads 2001-2004' started by MonishS, Feb 14, 2002.
  1. MonishS
    MonishS Auditioning
    Jan 31, 2002
    5
    Hi
    I finally have my different components ready: a Denon 2802, Definitive Tech speakers, DirecTV and DVD, VCR . I used an optical cable to connect the audio from the DVD to the receiver. I used composite (which I understand as the Yellow, White and Red cables) to connect the output of the satellite receiver to the Denon and composite (Yellow) to connect from the Denon to the TV. My TV only has composite input as an option apart from coax.
    My question is: since my TV does not have an s Video capability, is there any point in buying S video to connect from the satellite receiver to the Denon and to connect from the DVD to the Denon? My understanding is that the TV will never be able to tell the difference in the quality anyway, so it's probably OK to go with composite
    Would appreciate any and all help here
    Monish
  2. Scott_G
    Scott_G Second Unit
    Jun 18, 2000
    268
    Since the final source (TV) doesn't have Svideo. I don't think it helps much to use Svideo at this point.
    Seeing you have a good start, I'd look at upgrading the Video next [​IMG]
  3. MonishS
    MonishS Auditioning
    Jan 31, 2002
    5
    Scott,
    Thanks for the answer. As for upgrading the TV, I think we have blown our budget for the next 6 months but then should be looking for HDTV of some kind...
    Monish
