Newbie Help build Media PC
Discussion in 'Beginners, General Questions' started by Haqsta, Sep 25, 2006.
  1. Haqsta
    Haqsta Auditioning
    Sep 25, 2006
    2
    Hey guys,
    I want to build myself a full home theater but firstly i have a few questions.
    1. What do i need? What are good parts to use on pc.
    2. WHat spec pc do i need? If i have a very high spec will it perform better??
    3. Does the audio system require an amp or does it drive from the pc sound card??
    I want to be able to watch tv,cable,play games,mp3 & music and surf the web...
    It would be nice if you guys can give you a spec guide of your own systems
    Please advise on how i can do this.
    Thanks in advance.
  2. homthtr
    homthtr Supporting Actor
    Sep 5, 2006
    519
    First you need a Budget.
  3. Haqsta
    Haqsta Auditioning
    Sep 25, 2006
    2
    Do not really have a budget but i guess i would look to be spending $1000-$2000 on a decent pc system.
  4. homthtr
    Sep 5, 2006
    519
    Just the PC?
    I'm having a PC Built right now....
    Dual Dual Core.. Yes... Dual Dual.. not just Duo-core.
    2 Opteron 2212 Dual core cpu's
    1 terabite hard drive space
    4 gigs Ram for Video Rendering( I edit and Render lots of Video)
    PNY Quadro NVS440 x 16 Video Card ( enough to run 8 VGA Monitors)
    and some Misc other hardware DVD Lightscribe burners (4), etc...
    $3100.00
  5. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Try the HTPC forum at AVS.
