Adam.Heckman
- Dec 9, 2003
I appologize if this has been covered, I have looked at the primer, but to no avail. This may be due to my ineffective searching though.
I'm looking into getting HD. My question is this: are all HD tv sets equal in their lines of resolution? HD broadcasting is done in 1080i, correct? Do all HD sets come able to produce 1080i, or are some maxed out at 720p? And what is the native resolution of DVDs? Is it 480p? What about upscaling them?
Also I'll be looking into getting a 30" HD monitor, is there anything that I should be looking for? Is upconverting important?
Thanks in advance.
Thanks in advance.
