Newbie Connection Question
Discussion in 'Playback Devices' started by BenKof, Jun 14, 2004.
  1. BenKof
    BenKof Agent
    Feb 23, 2004
    25
    Looking for some help here .. I just brought a new HT receiver home and am now confronted with way too many connections issues. Might be a dumb question, but is there any "must have" set of connectors/cables that I should buy? For example, I need to connect my DVD player and my cable box to the receiver .. do I use optical cables or S-Video? I'm thinking I should just head to Best Buy and get two of everything to be on the safe side.
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Ben, you're confusing two different kinds of connection issues. For video, either use a set of component-video cables (Y/PbPr) or an S-video cable and connect the DVD player directly to the monitor/display. Use the receiver's similar connections only if space is an issue.
    But for audio and to be able to enjoy one of the digital surround-sound modes, use either a coaxial or an optical cable (doesn't matter which) and connect the DVD player's digital out to the receiver's digital in. (And then make sure that Dolby Digital and DTS are enabled in the DVD player's audio set-up menu and that your receiver's inputs are assigned accordingly.)
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Oh, and as for digital cable, if the box has S-video capability, connect that directly to the display as well. If it's a high-def cable box, use the component-video outputs. And for digital sound, do the same as with the DVD player -- digital out to digital in.
  4. Johnny_M
    Johnny_M Second Unit
    Apr 6, 2004
    281
    damn, jack beat me to it. and his post sounds better so ill delete mine.
    ^what he said.
    Johnny
  5. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
  6. BenKof
    BenKof Agent
    Feb 23, 2004
    25
    Thanks everyone ... it's a lot clearer now.
    Ben
