Howard_S
- Nov 1, 2001
Do you guys generally try to buy the shortest cable possible or do you generally like to have some headroom. I mean sometimes buying a 1m cable is possible but 2m will probably give you a lot more headroom and so on. Do you guys generally try to be exact in your cable length or do you generally buy longer than you need perhaps so it can be transferred to other systems more easily or something?
