Newbie - Advice Planning to setup HT.
Discussion in 'Home Theater Projects' started by ehari, Feb 13, 2005.
  1. ehari
    ehari Auditioning
    Feb 6, 2005
    This site is great. I am finishing my basement and like to run the speaker wires first through the walls. I have a mid sized Receiver and surround Speakers (Kenwood), which I want to use first and slowly adding pieces together later. At least I want to finish the speaker wiring through walls, before sheet rocking. What is the ideal speaker wire for this ( 12/14/16 gauge)?. What are the specifications, I should look out for?.
    I am looking to do wiring for 6:2 system and double wiring, if possible. Any help appreciated.
    Hari
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Just get a giant spool of 12 gauge and run that everywhere. Effective, cheap, and it's what most everyone does.
    Depending on where you are you may need to run in-wall rated wire, which will be more expensive. I think our electrical inspector didn't care, so no reason to spend more.
