newbie 5.1 decisions
Discussion in 'Beginners, General Questions' started by Simon-d, Sep 7, 2003.
  1. Simon-d
    Simon-d Extra
    Sep 6, 2003
    15
    Hello
    I recently purchased a Toshiba 57H83 (rear projection) TV and now need nay want to purchase a 5.1 setup. Already have a progessive scan DVD player, satellite dish and VCR :)
    I'm not an audiophile and I'm on a bit of a budget let's say around $700 CDN, can go a bit above. Any suggestions? anything inparticular to stay away from?
    The room is 17ft x 15ft. Running cables is no problem.
    Thanks for any advice.
    Comments about the TV are welcome...ISF calibration read a bit about this... is it worth the money?
    Sy
  2. David Preston
    David Preston Supporting Actor
    Mar 23, 2003
    698
    Check out the RAD MIcro system at www.rutledgeaudiodesign.com it is only $750 USD. Very good set up. You have a choice of color also.
  3. Simon-d
    Simon-d Extra
    Sep 6, 2003
    15
    thanks for the link but $750 USD is $1,028 Canadian, abit too far above my budget.
  4. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    The Acoustic Research HC6, 5.1 system can be had for $300-$400 U.S.
    Very nice at the price.
  5. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    "I'm not an audiophile" Sure, neither am I, but I do want something that doesn't grate on my nerves. I also want to feel the bass.
    You're in pretty tough trying for a budget of $750, so you may want to piece it together over time.
    Look for a Denon AVR-1403, it's around $400 Canadian and matches well with Paradigms Atom bookshelf speakers.
    Look for 1 pair right now, as 2 pair would put you over your budget, and everytime you get a few bucks buy another pair for the rear, a center, and finally the sub.
    SURE, it may take you a while to get it all but it will be a much better system than a HTIB solution.
    Brent
  6. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    I have to agree with Brentl, build the best stereo setup you can now, and add extra speakers over time. [​IMG]
  7. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    I personally like Klipsch. There Quintets can be had for about $350 USA and it is a pretty good price. Also you might be able to make a component Klipsch system for around $600US but you will have to purchase a cheaper subwoofer...
  8. Simon-d
    Simon-d Extra
    Sep 6, 2003
    15
    thanks for your replies...I'll keep that in mind
