Jake_J_HT
- Mar 18, 2003
Before I bothered you folks with a bunch of questions, I want to make sure I should build my own sub.
My situation: I have no audio system currently for my soon to be arriving RPTV. I have a large open basement, 18' x 60', and the HT/music set-up will go in the middle third of this room. Usage will be probably 60/40 HT/Music. I love LFE and good bass.
My main motivation for considering DIY sub is value. While I like to build things and would be proud of my own accomplishment, the real reason would be to create a sub with performance that would rival a pre-made sub costing considerably more (I need to keep the cost under $1K, closer to $500 even better). Considering the size of my room, I may need a serious sub. I don't particularly want to dedicate weeks building a sub. I suck at cabinetry (oh, sure I could build a box built like a brick outhouse, but it would look like one too). This isn't going to be a hobby for me (well, not for the foreseeable future, anyway).
So, to help me understand the value equation, consider the following example: comparing to, say, a Paradigm PW-2200 or Hsu VTF-3(or other mid-fi subs), would the Parts Express 15" Titanic Dayton DVC complete sub kit (w/cabinet and 250W plate amp) completely outperform these pre-made subs (at almost half the price)?
If the answer is yes, what happens to the value equation if I used that same pre-made cabinet, but used the HS500 plate amp and a driver like the Stryke AV15 or Bluepoint BPD1503? What kind of pre-made would that combo rival (if it's even a viable combination, that is)?
You'll notice that my two example projects would probably take me all of an evening to put together. (don't get me completely wrong--I'll spend more time for significant gains in the finished product.)
Thank you in advance for the advice.
Jake
Jake
