New TV made arcing sound (32HS500) (1 Viewer)
Mark Hedges
Hello!
My Sony 32HS500 was delivered yesterday, and after using it for about an hour I heard an arcing sound and the picture flashed off for an instant. It seems to be working fine afterwards. Is this something I should be worried about?
Could it be related to my center channel speaker (JBL S-Center II). It doesn't seem to be shielded adequatly since it is causing a purple discoloration at the top center of my screen. Could this be causing damage?
Thanks!
Mark
Adam Brandner
I don't know if that's what's causing the problem, but I'd move that speaker ASAP. A few years back, I had a pair of heavy duty stereo speakers next to my entertainment center that caused permanent discoloration to the left side of my TV. I wasn't aware of what magnets could do to televisions at the time. Try mounting that center channel under the TV or a little higher above on a shelf or something.
Mark Hedges
I was talking to a tech at Best Buy and he said that the TV may have auto degaussed. Does anybody know if Sony Wegas do this during operation? I know they do it upon startup. It makes sense as I am having a problem with my center channel speaker.
Mark
Mike Hamilton
-TV's degauss upon turn on (on a Sony that is that "ka-thung" noise when it powers up.
-Get the speaker out of there. Sony uses an Aperature Grill (a series of piano-like wires stretched [picture a harp] vertically and positioned horizontally across the inside of the CRT. These wires can get permanently magnetized and then you are SOL.
-The snapping is common in the first 30-45 days of operation, especially if you live in a low huidity climate (4% here last week).
Mark Hedges
Thanks! It does seem that the snapping is fairly common judging by comments on other boards. I moved the center channel off the tv by about an inch using the Sanus TV shelf. I no longer notice any discoloration. Does that mean I am in the clear or could there still be problems?
Mark
Kcuster50
