New tubes for my ECP-4100
Discussion in 'Displays' started by ShawnWingate, Dec 28, 2003.
  1. ShawnWingate
    ShawnWingate Auditioning
    Dec 28, 2003
    11
    since it is my first post I will be brief. I have two projectors, one is a sony vph 1040 and the other is an Electrohome ECP-4000/4100?? the sony has 07MS CRTs and the electrohome has SD187s. From everything I have read the two are interchangeable.My reason is the tubes on the ECP are burned so bad it is almost unviewable, but the sony's are beautiful and I would like to swap them Thanks
    Shawn
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I'm not super-familiar with either of these projectors, and so I can't answer your question. Perhaps someone else here might know, but in the meantime, if nobody knows I'd also recommend you ask at the CRT forum at AVS. They know everything about these things...
    And also the procedure for tube swapping if you've not done that before.
    I do know that the ECP series uses Sony tubes, but I have no idea if they are interchangeable, or if you need to do some modifications to swap them.
  3. joey mr
    joey mr Stunt Coordinator
    Jun 26, 2003
    127
    hi i am a big fan of the crt fp displays if you want to know about everything that there is to know about these type of projectors give this guy a call or email him [​IMG] he is the man of crt's
    his name is curt palme
    [email protected] just tell him joe from toronto refered me to you .cheers
  4. ShawnWingate
    Dec 28, 2003
    11
    Thank you both for the quick responses. I found out over at AVS that they are in fact interchangeable and the 07MS tubes are just a brighter version
