New to Home Theater (1 Viewer)
Lester107
Chris
I am finally getting involved in the home theater scene because we just inherited my in-laws 5 year old 65 inch Mitsubishi WS-65511 DLP HDTV. I just hooked up the new Dish Network HD DVR receiver to it last night, and got a real nice 1080i picture. Of course I couldn't leave well enough alone and bought a Yamaha YHT-590BL surround system in a box and a Sony BDP-S350 Bluray player. The TV only has one 1080i component input (the other 2 only support 480i), so my plan is to run both the Bluray and Dish receiver through the Surround receiver and then out to the single HDTV compnent input. I wanted to post this before I tear into the boxes in case I need to return them. Does this make any sense to any of you home theater people? Can you see of any other obstacles I might face? Thank you
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Before you open the Yamaha, you should consider getting one that will decode the HD formats. After a quick search on google, it seems that this unit doesn't even have HDMI in. Suggest you look at the Onkyo systems (6100?) - the receiver is much nicer and the price will be close.
The speakers are not going to be the best in either one (or any HTiB).
Bob McElfresh
Hi Chris. Welcome to HTF!
I looked up the specs on Amazon for that HTIB and it says:
If this means it has 3 component inputs - and 3 optical inputs, it will work fine. Contact your dealer to see if this assumption is correct.
Joseph DeMartino
Florida
Joseph DeMartino
Just FYI: Based on both the model number provided and your desciption of the inputs, etc., you have a CRT-based rear projection TV, not a DLP set. The technologies are completely different. (For instance, there is no such thing as a 1080i DLP television. DLPs are either 720p or 1080p - like all fixed pixel designs they are inherently progressive, and always display everything at their own native resolution - de-interlacing and scaling inputs when needed. CRT-based RPTVs are interlaced and can actually display the resolution of the input signal without converting it.)
Joe
Staff online
almico
